lights
Hi Cris,
If the passenger side is still working then that will rule out the relays.
If you now confirm that the fuses for the drivers side are still good -F19 10A and F6 10A in the engine compartment fuse box, then your problem will be at the light unit.
Disconnect the plug at the light and check for power on pin 2 and 3.
Also check the ground point is clean and tight.
See how you get on with that first.
rsa760041
23
09-25-2015 01:33 PM
