long beep and won't lock when pressing door lock on remote
It has happened a couple of times only for no apparent reason. I press on the remote to lock the doors and I just get a long beeeeeepppp, but it wont lock the doors. First time it happened I just got back in the car, started the engine and turned it off again then got out and pressed lock on the remote and it worked fine. I figured maybe it had something to do with a window not being properly closed but I tested it by leaving a window half way open to see if it would lock and it worked with no problems .
Put your key in the ignition, wiggle it around a bit and remove - then retry the key fob. the gate over the key slot can stick, and it's switch being still open tells the system that your keys are still in the ignition - it won't lock with the fob and warns you about it.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
