long valve cover bolts broken
Old 07-17-2011 | 12:24 PM
JLperdue's Avatar
Exclamation long valve cover bolts broken
JF I NEED HELP PLEASE I AM IN THE MIST OF PERFORMING A VC JOB AND I JUST GOT THE RH COVER OFF AND I REALIZED THAT A COUPLE OF THE BOLTS ARE BROKEN OFF IN THE HEAD, I AM IN NEED OF ADVISE ASAP.....
Old 07-17-2011 | 11:06 PM
sparkenzap's Avatar
Well, broken bolt removal is an art. Although it is not difficult, learning how on a Jaguar cylinder head would not be my first choice.
If you have any bolt exposed, then sieze hold of it with vice grips and turn out. Otherwise, the process is to drill a hole (smaller than the bolt size, DIRECTLY in the center of the bolt), then use an "easy out" or bolt extractor. To drill such a hole, you need to center punch the broken bolt. It is best to use a reverse turn drill and it will sometimes come as you drill it.
One reason I said that learning on your head ain't such a good idea, is that it is easy to break the extractor off in the bolt and you then have a mess. Dremells and small chisels are next, which is not fun. Then you are looking at helicoils.
I would find a good machinist or millwright or mechanic to help you on this one. It is a relatively easy tak if it goes well. If not...well...
JLperdue (07-25-2011)
Old 07-25-2011 | 12:11 AM
JLperdue's Avatar
1ST: THX sparkenzap, I USED A BOLT EXTRACTOR + PB BLASTER + DRILL = JOB DONE!
OK, I SUCCESSFULLY REMOVED THE BROKEN BOLTS TODAY BUT I AM HAVING TROUBLE LOCATING REPLACEMENT BOLTS ONLINE
Old 07-25-2011 | 12:22 AM
plums's Avatar
Probably the big names like rockauto, or a forum sponsor like Nalley Jaguar.
dsnyder586
04-04-2019 03:38 PM
sogood
09-15-2015 08:35 AM
al_roethlisberger
09-11-2015 11:04 PM
philwarner
09-05-2015 11:05 AM
XFR_Gold
09-02-2015 01:24 PM
Quick Reply: long valve cover bolts broken
