Longevity Question
Longevity Question
I am a new owner of a 1998 XJ8 L, and a second time owner of a Jag. The first one was a 1992 VDP.......and I had a horrible experience with that one....only kept it for a couple of months. I wanted one after Ford got involved and got this one. It has 91,000 on it, and seems to have been services pretty regularly. How many miles, with regular servicing, should I expect to get out of this car, and how many problems am I to expect. Just wondering. Thanks.
RE: Longevity Question
Acquired a '98 VDP a few months back, 120K (mostly highway) miles, pretty well maintained overall. I got it for what I consider a very good price, as it was frommy brother-in-law'sbest friend.
I went through thecar from top to bottom and made a list of every thing I could determine it needed. After having my local dealer confirm all the major structural and system components were in sound working order - and that thereforeit was worth putting this cat back inshape - we prioritized the list, and performed those repairs needed to make it road worthy and more driver friendly This included some suspension andelectrical work,plus some minor interior restoration.After doing brakes and new tires (at a local shop per the dealer's suggestion), the car performs like new. I expect it to keep going strong for quite sometime. BTW, I am getting just over 20mpg on the highway, about 18 locally. Not too shabby for a big V-8.
Guest
Posts: n/a
Guest
Posts: n/a
Don't get a flush...just drop the pan, swap out the filter and fill back up with the appropriate fluid. I used Pentosin and have no problems for the past 500 miles. I only had 50K miles on the OD, but there was a significant amount of gunk on the bottom of the pan and around the magnets. I plan on swapping out a couple of littres per oil change until all of the fluid has been exchanged (that which was left in the torque converter). I have been told by a tranny specialist that this was the safest way to change the fluids on an otherwise 'sealed for life' unit. Flushing a tranny that has done more than 50K miles could equate to trouble, if not immediately, soon after. If you would like to do a 'safe' flush then you could try this proceedure:
Disconnect BOTH ATF cooler lines at radiator and place a container or pan under each line end (helps to have an assistant). Start engine, shut down after 1 or 2 quarts have come out one of the lines. Refill exact amount of fresh fluid in transmission (this keeps air out of the system).
Start engine again and repeat until clean fluid is coming out of cooler line. This is messy and time consuming but will purge all old ATF from transmission and torque converter. Then, reinstall the cooler lines and start the car; cycle through the gears, place in park and check the level per owners manual. Check for leaks. Top up as necessary after driving and heated up. Don't overfill.
This way youhave safely flushed the whole system...
