Looking to buy SLCM for '98 XJ8
Here's what I did:
Open the trunk
Open the battery cover under the trunk floor.
You will see the battery and a large fuse box.
The SLCM is under there.
You. Should be able to see your code number when you remove the fuse box cover.
It's at the bottom of the fuse box.
If not, Disconnect the battery.
Remove the 3 bolts holding the fuse box to the floor and lift out the fuse box carefully. Turn the fuse box over.
The SLCM snaps out of the bottom of the fuse box.
Be careful as there are 3 connections going into the SLCM.
Go on eBay and type in the code you see on the SLCM.
It seems this is a popular item on eBay.
Swap the new one in when you get it.
Open the trunk
3timejag (10-08-2016)
mhessen6
10-12-2016 05:37 PM
