Looking for the door piece behind the armrest
It's entirely possible I've just not stumbled upon either the proper name, or a part number, or anything of the sort.
Behind the door card of at least the front doors, where the screw goes in from under the armrest, is a white nylon (assuming) piece that clips into the door. It's about a 3 inch long tubular shape mount that the armrest screw screws into. The one on my passenger door has been missing since I bought the car, presumably lost by a previous owner at some point. However, since that is where the brunt of the force when closing the door is applied and in my case it's missing, it means that the tree-clips around the outside of the door have been subjected to more than their fair share of work. Consequently, now they're broken down enough to where that passenger door bottom is loose and actually squeaking a bit if the door sits just right after closing.
The problem is that I can't seem to find that piece listed, or even referenced, in any door parts diagrams or lists anywhere, save one. The only place I found it, at all, is in the XJ8 Technical Guide, page 15. but that's just an exploded diagram, and it has zero information in regards to parts or part numbers, or even descriptions. So I have no idea what this piece would be called, much less where to find one. There aren't any local yards that have XJ8s to pick from.
So if anyone happens to know where to find this piece, or what it's called, a part number, or suggestions (other than to take a block of wood and shove it back there to screw into - kidding, I wouldn't put wood into the door where it'll get wet and swell and make a mess...), I'd be grateful.
I believe it might be part KZR100014
SNG Barratt - The Ultimate Jaguar Parts Specialist
https://www.jaguarclassicparts.com/uk/part/KZR100014
Part 4
Part 4
Thanks for the offer. I did find an ebay seller from overseas selling a 10 pack for what amounted to just over $10 shipped, which was one of the cheapest I'd seen in a while, so I jumped on that. Hopefully I can make enough of them stick to help, and was able to find an insert for about $11. Granted, if I had a 3D printer, I'd just start making them lol. Those and the darn door handle cup screw caps. I think my doors now, will be all set with the exception of the driver's door actuator. Haven't had the chance to swallow a hundred dollar bill on that one yet..
