Looking to rebuild Transmission for 2001 XJ8
I have a 2001 XJ8 with approx. 107,000 Miles logged in. When it would not go into Reverse, I ended up having the trans taken apart to find the problem. After inquiring on the Jaguar Forum, and seeing where others had the same problem, the failed part turned out to be in the "A" Drum. To keep a long story short, lost confidence in shop that it was taken to, and I am currently looking for a shop in the Hampton Roads Virginia area(Chesapeake, Virginia Beach, Norfolk, Hampton) that specializes on rebuilding the ZF transmission. Any suggestions would be very helpful.
Received 1,794 Likes
Welcome to the forum Brown,
We normally discourage (a.k.a delete!) duplicate postings but in this instance it's sensible to ask for shop recommendations in the Region forum. Here's the link to your thread there for anyone following the topic:
https://www.jaguarforums.com/forum/u...3/#post1555042
Brown (10-20-2016)
Local BMW, MB, and other ZF users have had luck with Prices Transmission - one block North on Witchduck off East 264 in Virginia Beach. When I had my 01, that was where I was going to take it if I had transmission issues. For heavy work (too heavy for me at 74), I took it to Abacus Racing on Baker's Road in Norfolk, just West of US 13. Best alignment and wheel balance is Checkered Flag (Burts and AAA never got it right).
RJ237 (10-21-2016)
Thank you for the good feedback. I will check into Prices. I believe I have passed it a few times while traveling on Witchduck.
Brown
Found a Local specialty shop that is stating they can rebuild trans and install around 2400-2500. This is for replacing all soft parts, new torque converter and Labor. This is suppose to be for a complete rebuild including updating the Valve body and any other item that needs updating. They offer a warranty of 12 mths /12000 miles. They were advised that the problem was in the A drum and trans has already been dismantled. I am wondering if the price they actually gave me was for just rebuilding the A drive. Does this amount sound low for a complete rebuild? Also, should I be looking for a longer warranty period. I welcome your thoughts on this .
Brown
Brown
ZF rebuilt mine 18k ago in my XK8 and it is giving symptoms of a failed valvebody. They also warranty for 12/12. I think you'll find it tough to find anyone willing to stand behind it as it seems to be engineered in defects in the tranny and parts used rather than the quality of the rebuild. I can't even find anyone local to me willing to look at and diagnose the car. They only want to buy remanned trannies and install (taking on zero liablity). Good luck!
Brown (11-06-2016)
Brown
Brown
Just giving you some round numbers to look at.
Here's some results from a Bing search...
Transmissions | Automobile Repairs | Chesapeake, VA
Gene's Transmissions of Norfolk
This brought up 10 highly rated repair shops with ratings....
https://www.mechanicadvisor.com/va/c...mission-repair
Hope this helps....
Jaguar Forums Editor
08-29-2016 05:16 PM
