Looks like I need timing chain work. URGENT ADVICE NEEDED
#102
pull a plug wire off one by one and see if you get a change in any 1 cylinder to isolate it.
#103
have you made any progress on checking this out? While it sounds real bad, it is a little hard to hear well where it is coming from. I would want to rule out any issue with the drive belts and pulleys. You could loosen the tensioner and remove the belt totally and run it for a short wile to see what noise you get as well. You said you went through water, maybe it got into some open bearing.
#104
Took off the valve covers today.
This is what I found:
http://www.youtube.com/watch?v=wbhIxx-CFKg&hd=1
I'm pretty sure my findings are pretty self explanatory with my commentary in the video.
*sigh*
I'm gunna go drink myself to sleep.
*sigh*
#105
#106
#107
And it's not about prestige and style, it's about transportation to school.
The theory is that someone goes to school, graduates, gets a job, and *then* buys what they want with the money they earn.
There was a student in architecture school who survived by drinking ketchup packets mixed with boiling water as "tomato soup" and the fruit smuggled out of the dining hall by class mates. Obviously, no Jag or rich parents for him. But, he graduated.
#108
#109
#110
Have you dropped the oil? what does it look like? any metallic bits in there? now you have the tops off, I'd change the upper tensioners. Rotate the engine via the crank pulley bolt until you get the flats on the cams all in the correct place, either lock one side with the cam locking tool and go from there with the zip tie method. You know the tensioners work on hydraulic pressure if they're not pumped up fully you'll get chain slap, which is something I suspected from your initial video as the timing of the noise isn't engine speed.
Another suggestion is a compression test - you can do this asap - we have to confirm chain slip and valve damage. Easy at this point. You'll need a tester to screw into the plug hole, replacing the plug, and again using the crank pulley bolt to bring compression up in each cylinder, jot them down and post results here.
Next job after that would be to take the timing cover off, and inspect timing from top to bottom, lower tensioners and guides.
You're saving yourself a bundle right now, keep going.
#111
I haven't dropped the oil yet. I'll get to that this week.
Wouldn't it be worth it to just remove the oil pan at this point instead of spending money on new tensioners? The ones already on there look like they're in pretty good condition. No cracks visible. and I pushed and pulled on secondary chain at the tensioners and the cam pulley on both banks and the chain was tight as can be. I wiggled the primary chain at the cam pulley and there was no play.
Removing the oil pan would probably allow me to get to the sump so i can visually inspect the crank?
#112
#113
Ok, a Yaris then.
I know a guy like that. Today he eats the finest meals because of his discipline while a younger man.
#114
YouTube - Jaguar AJV8 Knock Assessment
*sigh*
*sigh*
#115
My wallet is completely empty because all of my money went into the initial purchase of the car and the transmission ($8k + $5200 for a new tranny), and now I dont have any money what so ever to try and salvage the car at the moment. I did not expect either of these things to go in under 4 months of owning the car so I am at the mercy of my mother's wallet and her decision making.
#117
I agree with Sean B about doing a compression test. It's hard to tell from the recording, but the sound doesn't sound like a rod knock right off. It would be fairly easy to do a compression test on all eight and see if they are all at least uniform. Also, if you can turn the engine over, while you have the cam covers off, check to see that the cam flats line up correctly at some point in their rotation. Maybe a mechanic told you he's seen spun rod bearings on Jaguars before, but I've never heard of it on a straight six or the V8. Jaguar bottom ends are generally bullet-proof and pretty hard to destroy unless you are really trying hard. Sorry, I don't remember if you said there were any trouble codes, but were there ? Pulling the pan and looking at the con rod big ends may not be conclusive unless there is obvious damage, so I wouldn't go there unless you're reasonably sure you'll find something.
#118
How do I turn the engine over without turning it on? I've never manually cranked an engine before (I've never been in a situation where I've had to).
#119
A compression test will reveal if you have a bent valve or a blown headgasket. I have not turned one of these engines over by hand either. You could try turning by the crank bolt, which may not be easy, or you could try bumping the starter. Have you tried turning it over (with starter) without the spark plugs in it to see if you can hear any obvious mechanical problems ? You would need to do that for a compression test anyway. So, the engine runs pretty good except for the noise ? and you've gotten no engine codes ? I'm just suggesting that you eliminate the possibility that there is a cam chain or timing issue by checking the cam flats, and a compression issue with the compression test. These are both relatively easy and free - if you can get hold of a compression tester.
#120
