Loose door mirror
Old 01-15-2019, 02:54 PM
cliveb's Avatar
Default Loose door mirror
Hi, does anyone know how to access the passenger ( US model) door mirror mounting, mine is slightly loose and vibrates while driving. I'ts not the mirror itself, but where it mounts to the door. I copied a photo already on this site to illustrate the area.
Clive
Old 01-15-2019, 05:52 PM
SteveXJ8L's Avatar
If the entire mirror is loose, you need to tighten the mount. Carefully remove the black trim piece in the inside of the door, and under it is a Torx bolt that will need tightening. A drop of Loctite on the threads wouldn't hurt while you're at it...
Steve
vdpnyc
01-05-2020 02:29 PM
skubeedoo
01-07-2016 11:52 AM
Spikepaga
09-13-2013 11:35 PM
in2
01-12-2011 02:44 AM
10-28-2010 11:12 AM
Quick Reply: Loose door mirror
