Loose Lug Nuts Caps
Loose Lug Nuts Caps
I've noticed that my car makes a very light rattling noise over small bumps at slow speeds. I assume it was the center caps since my old car did the same and they were loose. Pulled them off and tightened them up and the noise didn't cange on bit. After poking around I realized its the caps on the lug nuts. None of them are loose enough to slip off, but I'm sure other have run into this before - what's the best way to remedy? Anything over 15-20mph you don't hear them, but a Jag should definitley not be making faint rattling noises when cruising through a parking lot.
In the past I have gone as far as removing the stainless steel lug nut covers and put a bit of silicone on the inside flats and put it back on. If you happen to visit a junkyard, you could invariably find some other lug nuts to see if their in better shape than yours. Since you have a 98’ with the Penta’s, you likely have the long shank lug nuts. Go find one with the short shank lug nuts in the junkyard. They’re a lot less likely to rattle in my opinion.
I kept the old jangly nuts, peeled off the stainless caps, and now use them under my Solars' hubcaps. Without the domes, they can accept the same 21mm drive as the Gorillas. I had a spare 21mm emergency lug wrench around from when I changed my Miata to 19mm drive lugnuts, so it all worked out alright.
For my 20-spoke wheels with exposed lug nuts, I went with Gorilla 73187SMB. They look nice and don't rattle but the washers aren't captive.
