Lost Radio Code XJ8
After you get the code and get the radio working you might scratch the number somewhere like the boot floor by the spare wheel. If you live in the US you need to set the radio to US and enable RDS if you want that feature. If set to US RDS it should not require a radio code again, but if you change countries then you loose all your preset stations. There are features that can be enabled/disabled like tape head and aerial cleaning reminders, tape eject on/off etc. All info should be in your ICE booklet and it is also in a TSB 415-06.
bob gauff
bob gauff
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Does this apply to the US 1998 XJ8 Model? some say US models do not require a code, im planning to do a hard restart but the the previous owner said he did not need to after changing the battery and alternator but i just want to make sure before i do a hard restart.
thanks guys! your all so helpful!
![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
thanks guys! your all so helpful!![Icon Dance Disco](https://www.jaguarforums.com/forum/images/smilies/icon_dance-disco.gif)
Hi,
I remember overriding the radio-code with my 03 xj. I found the instructions and this is what you should try:
try the following - ( this is a method to reset the unit )
Press the FFWD and PTY buttons for a few seconds to override the the code.
Some models- you need to press the A.MEM, >> and PTY together.
I hope this works for you.
Just reset my 02 x type using >> A.Mem PTY
All pressed at the same time, did,nt work first few times.
tried again 20 mins later after driving car before turning
engine off when reaching my destination. Worked then.
Think if it does'nt work straight away allow 10 mins before trying again.
good luck.
good luck.
Thang Nguyen
10-12-2015 01:25 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
