lost window control after hard boot
Received 3,910 Likes
Rua, if your car is like the X-Type, what you need to do is to do one window at a time and first roll the window all the way down manually (ie, holding the button down) until the window reaches the bottom, then hold the button for a few seconds more (normally about 3-4 seconds is more than enough). Next, hold the switch in the up position till the window reaches the fully closed position and then continue to hold the button in the closed position for a few more seconds. Repeat for each window and this should restore the auto up/down feature.
ruaporpoise (07-11-2011)
If you disconnected the driver's door switchpack with the battery connected, you will probably need to reboot again (or you have a faulty switchpack). The 99 XJ8 does NOT have one touch window UP (I KNOW I HAVE ONE). Disconnecting the Battery will NOT retime the sunroof control module, only physical retiming will work. Do a search and find all the TSBs I have posted lately for the sunroof faults.
bob gauff
bob gauff
ruaporpoise (07-12-2011)
THANKS AGAIN Motorcarman, I only have drivers window and memory settings at switchpack, no mirrors or other windows. and drivers door open indicator are all a result of removing the door panel to repair door check. The battery was connected. I will try a reboot. I have read all I could find on re-timing sunroof but am unclear on where the white dots are or how to line them up. As always I am most greateful for your shared knowledge and time!!
Thang Nguyen
10-12-2015 01:25 AM
