loud clunk when braking
Just got the car back ,they fitted another diff.
It hopefully has nothing to do with that last repair but..after getting it back
When i pump the brake pedal when coming to a stop ,
The car clucks and jumps up and down ,it sounds and feels like the brake calipers are
loose ...but of course they not..
Could it be the subframe mountings ,? this really scares me ,any ideas
Where to look first,?
Another problem ,i also have a ABS Trac /Stab light
When i drive the car and it goes in second gear the light goes out....{i will
Have it checked for codes} ,hopefully thats only a ABS sensor lead ...
DJ-Roy (09-23-2013)
I'd be suspicious of the recent work too, if the above checks don't reveal anything, it's got to go back to the shop you had the diff change work done, and show them.
Did you get the shock bushes done too?
or engine mounts, with one foot on the brake, rev the engine lightly see if there's abnormal movement from the engine.
@Sean ,I ordered the rear lower shock bushings ,
The engine mounts and rear trans mount are new ,
Hoped that would solve the problem but it is still there .
I already went back to that garage that placed the diff ,,
They found a front Cats Shock with movement on the Shock Shaft ....replaced that shock and bush so thats tight ,
But still the heavy shuddering and bounce under pumping repeated application of the brakes.
@Jhartz
I also thought they made a mistake with the rear diff swap ,
But the knock really seems to be coming from the front ,even though its sometimes difficult the locate a problem on these cars ...if the front subframe bushings are ok then the rear is the next to look at...
Just found that it dont knocks and bounces , when i repeatedly apply the Brake pedal .. .......when i drive backwards.
DJ-Roy (09-23-2013)
philwarner
09-16-2015 10:40 PM
Johnken
09-15-2015 05:46 PM
