low amperage, wasnt the alternator
2001 xjr, bought it last week.
ran some tests, everything looked good except the battery was receiving low amperage from the alternator, ok, had the alternator changed, still low amperage... went back and bench tested the old core, passed just fine. now it is narrowed down to something between the alternator and the battery im assuming.
what could it be?
note: on the navy base we have a shop we can use with lifts and tools, so i have plenty of tools at hand
what could it be?
navy nuke (03-24-2013)
What is the condition of the battery itself? Leave the vehicle for a few hours with the engine off & then measure the battery voltage. It should be above 12v & ideally above 12.5v. If it's well below that then either the battery is flat & needs recharging before doing any alternator tests, or the battery has a dead cell which is dragging down the main system charging voltage from the alternator.
Once you've confirmed that the battery is alright & fully charged, then you can begin investigation of the charging issues. With the engine running, measure the voltage at the battery itself & then directly at the output of the alternator.
If you're getting around 14v at the alternator but only 12.5v at the battery, then the problem is either the engine ground strap or the false bulkhead connector having high electrical resistance.
I'm wondering if there's a problem with the battery, as an engine idling with no heavy electrical loads would not require 30 amps from the charging system-it would normally be less than 10 amps or so.
It looks like the alternator is putting out a decent current to maintain the system voltage, but something is dragging it down & that's usually the battery with a failed cell etc...
got off school early today and to it to the hobby shop threw it on the lift, first thing i saw was the engine ground strap, scotchbrite pad and some cleaning, battery not charging went away. went ahead and did the same to the rhs false bulkhead stud connector also, thanks a lot.
also i let the car sit and then tested battery, 12.54v so thats good
Thanks,
MM3 Moroz
Thanks,
MM3 Moroz
Another success story at no expense. Good work. When I was in the Navy back in the pre- Vietnam days my ship spent a couple of summers at the Philly yard. They had a great hobby shop there and we rebuilt a friend's Healy 100-4 engine and gearbox while there. They even had Whitworth taps & dies.
scooternva
19
10-27-2015 02:14 PM
rsa760041
23
09-25-2015 01:33 PM
