Low brake fluid indicator
Please clarify: has the pedal gone spongy? If so there is air in the lines. But that should not cause the low fluid message.
There is a float in the fluid reservoir, and it sometime sticks or actually sinks. If you use the search function you will find some threads that address this problem.
aholbro1
08-05-2021 05:02 AM
Richard_gib
09-12-2015 07:08 PM
Wes Steenrod
09-06-2015 06:52 PM
