Low compression in one cylinder
I recently did a compression test on my 98 xjr due to my misfire code on cylinder 4. Come to find out it’s has low compression in on cylinder out of all of the others.
The compression was 75psi what do I do to fix this problem on a budget avoiding buying a new engine?
I did actually poor some oil in that number four cylinder which had low compression and it did bring up the compression to the recommended rating. The car has just over 100,000 miles on it.
should I try rislone ring repair additive to see if that fixes the issue.
i’m also thinking maybe the car has a broken or stuck piston ring how would I determine which one it is
The Moneypit
05-02-2018 09:37 AM
