Low Coolant light, but barely needs coolant
Twice in the last 3 weeks the low Coolant warning came on, both times I let the car cool overnight and added coolant the next morning and the reservoir only took about 1/2 liter if even that much before reaching the top.
Is my coolant float sensor defective or is it supposed to be so neurotic about low Coolant? Or is this symbolic of another issue?
Temp gauge is always normal, never goes past the half mark.
I have found that my coolant level stabilizes if I leave it about 6mm/1/4"
below the filler neck and then it never moves.
What sort of mileage has the engine done?
Check the operation of your level sensor by giving it a poke with a slender stick or biro to make sure it's moving up and down freely.
Check the wiring connector below the expansion tank.
Be interesting to know which tube/hose was involved? ;o)
