Low Coolant Warning
Muhammad Umer (08-23-2016)
Probably not related to the button selector, but you might have brought more heat in during some spirited driving.
As mentioned, it can be several things, and might take a bit of observing time to find.
Can be just too low level, a leak, the reservoir cap, the thermostat, or a warning of something to come ...
Just be very careful not to overheat the engine, the instrument gauge in NO indication of what is really going on.
It will stay in the middle most of the time, only to shoot up once it is almost too late.
On a side-note, THAT is a beautiful car, don't see many with a body kit around.
The low coolant level comes on at 1/2 tank. Not much of a leak and you will see it.
Carry a gallon of water in the trunk. It serves many purposes. If the car breaks down
for whatever reason, it is nice to have while you walk to civilization or await rescue.
It is handy if the reservoir is a little low. If you have to keep adding water every month, then you need to find and fix the leak though
DanielSWE
03-28-2016 06:22 AM
