Low knock fron RH side of engine
About six months ago I heard a low frequency knock from the RH side of the engine. Just audible at idle, standing beside the engine with the hood up.
I thought that it was the alternator bearings on the way out (wishful thinking!).
Recently I got a stethoscope and hunted around. I cannot target the noise. The knocking increases in frequency with higher engine revs before being drowned out. I can hear it through the alternator housing and RH belt idler.
I was thinking of taking off the serpentine belt and briefly running the engine to eliminate accessory noise. Will this damage anything?
Am I looking at main bearing damage?
Thanks again,
Dan
Thanks again,
Dan
It seems that we both have the same problem only mine is on a 99xk8. Shame on Tom not to tell you or me that!!!! Take a look at my post https://www.jaguarforums.com/forum/s...ad.php?t=29520 I replaced the belt for the second time the other day and still have the problem. I am going to replace the tensioner and idler tonight and see what takes place. I will let you know!
BrentGardner
28
04-26-2024 03:08 AM
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
08-30-2015 09:49 PM
