Low oil engine now what?
Yesterday day changed engine oil the mechanic added 6 liter instead of 7 liter i even asked him he said yes i added 7 liter today discovered my engine was running on 6 liter of oil . Now i can hear strange sound under the camshaft cover its like old rusty fan sound ! I did add 1 more liter but u think its too late there's a damage already or serious damage is on the way
Guys do u think serious damage happened? And did anyone of u had same situation?
Received 1,816 Likes
How long did you drive it with the 6 and how long have you with the 7?
Read this TSB and check your dipstick... http://www.jagrepair.com/images/TSB/...il%20level.pdf
No knocking sounds but that like fan sound under the cam cover worrying me . Didn't go beyond 3k rpm
While it is not advisable to run an engine with less than the recommended oil level I doubt any harm was caused by being a liter low in a 7 liter system, especially just 40 miles at low rpms.
Six liters would probably put the oil level at the "MIN" level on the dipstick. I can't think that it could in any way be responsible for the noise you are hearing.
days ago the breather hose that's connected to the air intake was broked i didn't know that until i opened the hood so used some glue and tape to fix it temporally until i get hose and fix it .
There is a 'breather' hose on BOTH cam covers.
Air into the engine from the air filter on the right side (FULL LOAD BREATHER) and air out (into the intake, PART LOAD BREATHER) on the left side.
If the oil light did not come on during driving, I doubt anything is wrong because of the low oil level.
Early Jaguar V8 engines were fitted with a longer dipstick and a lower oil fill. (probably what you might have had before you added a quart)
During high cornering loads it might be possible for the engine to draw air if the oil pickup is uncovered with the oil pulled away to the side of the pan.
You might encounter this if you are a fan of 'drifting' you car!!
Jaguar engineers recommended adding a liter and a new dipstick marked accordingly. (see GENERAL INFO TSB 100-17)
Carnival Kid (03-08-2020)
Today i drive for about 50 miles below 3k rpm car run fine but that sound just strange .
I think its beyond my knowledge i will take my car to jag specialist i don't want this engine to die but unfortunately more cash will go
Well guys it was the water pump i couldn't figure out by myself i went to the mechanic friend of mine he has good knowledge and show me leaks from water pump and he said change it and the noise will go i installed after market water pump and new serpentine belt dayco belt . What surprised me is the serpentine belt never changed it was the original from 2002 And looks fine
Thank you all for help
ericjansen (03-10-2020)
REVANTH KUMAR
08-07-2019 06:08 AM
tibam13
09-19-2014 11:27 PM
sqenixs
08-02-2012 12:36 PM
