Low oil pressure... oil level fine
Greetings,
First time ever 'Low Oil pressure' warning came end of last week, shortly after I left the office. Fortunately just besides a parking lot and pulled in. Checked oil level and was at min. I added a quart. The warning remained on a little, at idle, eventually disappeared revving a little and gone for good. So I thought I had just been too low on oil. Today - warning came back on when starting the car! I checked the oil level again - this time, level is good. The warning would be there at idle, goes away revving a little, then back on at idle. After a few of these operations, the warning was gone and drove it a few miles back home no issue. Before asking for advice on what to consider, I do have oil leaks. At rear crank seal and timing belt cover. I have replaced the valve cover seals not that long ago. So do I have a serious enough leak to cause a loss of oil pressure? Oil pump going out on me? Cheers?
Blue_XJ8 (11-16-2015)
If that doesn't work, consider dropping the pan and removing the oil pickup screen. There may be pieces of plastic from the chain tensioners or guides blocking the flow.
Have you checked to see which secondary tensioners you have?
The oil warning light goes out at about six pounds pressure and the gauge will read mid scale then. So you could have low pressure and not realize it.
I see test point was quicker than me, as usual.
Thanks all for your replies. I am due an oil change anyway, so will go the extra step removing the oil pan and have a look if anything clogging the pump pickup screen. Guess can't hurt to replace the pressure switch. I ultimately need to take care of my oil leaks at some point (I think I am going to adventure on doing the timing belts/engine front cover myself, but don't believe I am equipped to do the rear crank seal one). As to the plastic tensioner... I have always heard about this but never really known if that orange looking plastic 'flat surface' on which the chain slides on was the plastic portion referred to here, or more to the little unit.
LVStreetterror
12-09-2015 05:42 PM
Harry Dredge
11-20-2015 03:27 AM
