Low Washer Fluid warning
I've had this, open the header, there's a float, it's probably stuck in the low position, i just slid the float up and down on its shaft with my finger until it was moving freely, no light afterwards. Another possible cause is a bad sender, this connects underneath the header tank, and pops out. Swop for a good one if fingering doesn't work.
Don't be dirty!! Only Messin!!
Whilst we're on the matter is the tank easy to remove? As I mentioned I have a leak in mine I need to fix and I aim to get the fluid level sensor working again also whilst I'm there.
Ta, Stu.
Ta, Stu.
aholbro1
08-05-2021 05:02 AM
pnwrs2000
01-15-2018 07:20 PM
al_roethlisberger
09-11-2015 10:04 PM
