MAF sensor changed….runs worse
Old 06-24-2024, 03:57 AM
Hooli's Avatar
Originally Posted by dwhx300
So today while I was out and about, I decided to get some Techron at the auto parts store, seeing that this would be my first fill up since I bought it. I poured it into the tank, screwed the cap on, got in, and the check engine light went away, and now it is running as smooth as can be. Question is, could a loose gas cap cause P0174?
Any hissing noises when you take the petrol cap off? These old heaps have a habit of getting a vacuum in the tank due to the breather system. I guess if the vacuum gets bad enough it'd cause fuel flow issues.
Just a thought as disturbing the cap seems to have made a difference.
Another thought is pickup filters blocked in the tank giving similar problems & filling up washed some dirt off the filters till the pump sucked it back again.
Old 07-11-2024, 12:43 PM
dwhx300's Avatar
Soooo a little update, I had the fuel filter replaced, and now my P0174 code is now gone. However, I still have a stumbling idle. When either gently accelerating or staying at constant speed, it will still stumble, but if I really put my foot into it, it accelerates fabulously. Any suggestions?
Old 07-11-2024, 01:07 PM
Silverjag0's Avatar
The car is 20 years old I think that's normal for now later check your spark plugs and their seal it might leak oil causing misfire get iridium ngk or platinum Bosch I tried all denso spark plugs it just not for our engine
Get 4 inch kn air filter get rid of the air box it chock the engine I had engine vibration at 40 Miles I removed the air box and just installed 4 inch kn air filter it breath better now
Old 07-12-2024, 10:26 AM
dwhx300's Avatar
Silverjag.....did you use any kind of heat shield to surround the K&N in the engine bay?
Old 07-12-2024, 11:06 AM
Silverjag0's Avatar
Unfortunately no
Old 07-12-2024, 11:34 AM
Jhartz's Avatar
I would check for leaks around Bank Two: VVT seal, O-ring on dip stick . . . clean the throttle bore and plate; check for leaks around throttle fittings; take up slack in accelerator cable; make sure no leaks in air tube. How dirty is the air filter?
yellowbandit
04-12-2023 06:13 PM
Scotlad
01-08-2022 12:47 AM
Six Rotors
02-10-2015 09:27 AM
powerhouse
08-04-2014 10:50 AM
Donzi
03-01-2008 06:58 PM
Quick Reply: MAF sensor changed….runs worse
