Manual adjustment of steering column
I have a 1998 model Daimler V8. I have issues with the steering column.
It will move up and down okay, but the reach does not work. I was given the replacement part when I bought the car to amend this.
This is not the main issue, when I have the wheel set to its maximum height via the motor, it still looks like there is room for another couple of inches movement upward.
I am assuming that this may be due to the reach not working.
The steering wheel is a tight squeeze when getting in and out of the car, which also leads me to think that the column will move higher.
Is there a way of disconnecting the motors and adjusting the column to be permanently in the correct (comfortable) position?
Thanks in advance.
Thanks in advance.
it's a simple job to swap the motors out and have a working adjustment both ways, it's nice when it works. Typically under an hour to do so maybe contact a Jag specialist in your area, if your round my way I'd do it.
There isn't a way of manually adjusting a power column short of stripping it and the motors.
Welcome to the forum.
aholbro1
08-05-2021 05:02 AM
Richard_gib
09-12-2015 07:08 PM
jagent
09-12-2015 09:10 AM
