MAP sensor question to all techs
Hi,
I'm interested in buying this Scan Gauge II which displays 4 live gauges at a time.
ScanGaugeII : Linear Logic - Home of the ScanGauge
My question was since my 2002 XJR has the MAP sensor, that is reading total boost, right? and therefore this Scan Guage thingy would be able to display the live amount of total boost right? (you can laugh if you need to, just please answer the question)
I'm planning on having the gauge display Intake air temp, water temp, boost, haven't decided on the 4rth yet...
WaterDragon (06-27-2012)
Andre is the SuperchargeMeister but I believe once past the throttle body there's nothing until the oxygen sensors which simply adjust the fuel injection time for the best stoichiometry so they don't need to know about boost pressure.
This is why you can increase the boost without having to change the ECM fuel maps.
EDIT - Andre beat me to the post - he's already replied.
What I am looking for is a sensor that reads the temps after the blower has compressed and heated the air..
Again, I think I will have to install my own and run its own gauge
I may just hook up a dual gauge showing boost and IAT and try to hide it subtlety in the passenger compartment as I don't want to give any outside hints that the car could be fast, when it actually becomes fast.
KarimPA
09-12-2015 08:15 AM
