Mark Peter's Jaguar Ownership Thread
Old 05-11-2023, 01:48 PM
RandyS's Avatar
Very nice....kinda reminds me of my old Mark X. Wish I still had it.
c16rkc (05-12-2023)
  #42
Old 05-11-2023, 06:57 PM
Ken Cantor's Avatar
Received 2,537 Likes on 831 Posts
Oh the list of "wish I still had it" cars... It doesn't apply to all the cars I've owned but it would probably include these: '52 Pontiac, '62 Volvo 544, '58 Borgward Isobella, '74 Fiat Spyder, '56 Jensen 541R, '87 Jag Series 3 V12 VDP, '95 Grand Cherokee, '92 Jag Series 3 V12 VDP (Number 24 - I still own Number 3.
"Wish I still had it" would probably be an interesting thread all on its own.
c16rkc (05-12-2023)
  #43
Old 05-12-2023, 03:42 AM
markdpeter's Avatar
Originally Posted by c16rkc
I don't remember having any brakes done, so I am not sure about those brake shoes; from memory the car was at a Jaguar specialist in Norwich in early 2020 for the MOT and they might have been done then? - Very scary about the front discs... I wonder how long they were like that.
Thanks to your great records, I can tell you that the brake shoes were replaced were replaced in April 2020 as part of all that MOT work
But this is perhaps the part that concerns me most now. This bit in white below was made of chocolate when I dropped it off to him. It was pretty much made of filler and he told me he even found a coke can used to shape it in one side. He said he welded in new metal, and that the filler was just to level it off. I banged it with my finger and it seemed like steel to me. I am hoping this was the case as this is a real trouble area for these X308's.
The external work on the wings was good, Chris. It's just the inner wheelarches which were covered with filler. Between the mechanic and the bodyshop, I think I can be fairly confident that they've found everything.
I've also got a reconditioned rear subframe with new bushes being delivered today. I need to work out whether that's something I can do myself.... Any advice is appreciated.
  #44
Old 05-12-2023, 06:16 AM
c16rkc's Avatar
Thanks Peter - that's a relief that those outer wings are OK then - I never thought about the inner parts of the wheel arches. It is possible the bodyshops I used never touched those as I only showed them the outer arches and the rust on them.
You certainly do have a good team between your mechanic and bodyshop; the car will be better than when it rolled off the production line
markdpeter (05-18-2023)
  #45
Old 05-18-2023, 04:23 AM
markdpeter's Avatar
Daimler still not back so I'm making maximum use of the XJ6 during this dry period. I took it to the Everton match on Sunday (so I can at least look forward to the drive home) and when I came back it was parked between these two monsters. I know it's a recurring theme but it really is amazing how a large car of its time is now tiny.
The following 5 users liked this post by markdpeter:
944play (05-18-2023), c16rkc (05-18-2023), GGG (05-18-2023), Hooli (05-18-2023), sov211 (06-20-2023)
  #46
Old 05-18-2023, 05:30 AM
c16rkc's Avatar
My goodness that's incredible; I had not realised how small a SIII was next to a BMW X6. How things have changed!
The "Lucy" and "Ted" numbers plates make the photo quite comical
  #47
Old 05-18-2023, 05:48 AM
markdpeter's Avatar
I hadn’t even noticed that - brilliant!
c16rkc (05-18-2023)
  #48
Old 05-18-2023, 06:58 AM
Hooli's Avatar
Wow I hadn't realised the size difference either. I bet there's as much room inside the Jag as those heaps too.
The following 2 users liked this post by Hooli:
c16rkc (05-18-2023), markdpeter (05-19-2023)
  #49
Old 05-18-2023, 08:03 AM
Ken Cantor's Avatar
I know exactly how you felt…
The following 2 users liked this post by Ken Cantor:
c16rkc (05-19-2023), toaster (06-26-2024)
  #50
Old 05-19-2023, 03:40 AM
markdpeter's Avatar
"Mini" - a real contradiction in terms.
c16rkc (05-19-2023)
  #51
Old 05-19-2023, 03:51 AM
markdpeter's Avatar
Default Almost There
LIfe has got in the way of the bodyshop finishing off the work but they're getting close to my being able to pick it up. They've shared a load of photos so here's a small selection:
Getting rid of those car park dinges.
Rear window out to treat the rust in the surround.
Fixing the DIY fix and paint that Chris had sorted out.
Looking good but that exhaust is rusty. I think I'll replace that centre box with an x-pipe as there's a leak.
Wheelarches done - note the missing bump stop
And same on the other side.
Driver's side sill done.
c16rkc (05-19-2023)
  #52
Old 05-19-2023, 05:40 AM
Hooli's Avatar
Both my bump stops are missing too. When I got the car one was missing, so I removed the other. It looks right to the MOT guy now so he can't see anything is missing to fail it on.
c16rkc (05-19-2023)
  #53
Old 05-19-2023, 05:42 AM
markdpeter's Avatar
Good plan. I suspect I’ll just leave them off as I think the mounting holes/bolts may no longer be there.
The following 2 users liked this post by markdpeter:
c16rkc (05-19-2023), Hooli (05-19-2023)
  #54
Old 05-19-2023, 06:30 AM
Hooli's Avatar
I think the rubber stop was only bonded to the that metal plate, pretty sure you get both bits if you buy new ones. My other reason for not replacing them is I didn't fancy snapping the bolts that hold the metal part on & ending up with a log bigger job for something that doesn't cause me a problem. It's rare there's more than two people or any luggage in my car so it's hardly likely to ever need bump stops in use.
c16rkc (05-22-2023)
  #55
Old 06-18-2023, 12:05 PM
markdpeter's Avatar
Default New Brakes
I got the car back from the shop last week and yesterday set to installing the new front discs and pads, and the anti-roll bar bushes and drop links that arrived when the car was away.
I’ll post photos an update on the work done in the shop during the week. In the meantime, however, I had to post a photo of the disk pads I removed yesterday. If you recall, the car had the wrong size disks - you can see in this photo the impact on the pads of the missing 20mm of disk diameter! Look at the lip on those pads!
I just got back from a quick test drive - a great improvement and way better brake feel, and all the clonking has gone from the front.
The following 3 users liked this post by markdpeter:
c16rkc (06-19-2023), Hooli (06-19-2023), Ken Cantor (06-18-2023)
  #56
Old 06-19-2023, 04:21 AM
c16rkc's Avatar
That's fantastic news.
  #57
Old 06-19-2023, 05:12 AM
c16rkc's Avatar
Are you still taking the car on your trip at the end of June?
  #58
Old 06-28-2023, 12:41 PM
markdpeter's Avatar
I'm off to France tomorrow morning for the Le Mans Classic - sorry that I didn't reply to your last message @c16rkc but there's your answer!
All levels are checked, we're fueled up with 99 Octane E5 fuel and I've adjusted the tyre pressures for Autoroute speeds. The car will click though 100k miles on the way down to Portsmouth but I'm confident that we'll have an uneventful drive. It's a round trip of 1,000 miles so I'm looking forward to using the car in the way it was intended - my friends in the rear seats are going to have a luxurious experience.
aquifer (06-28-2023), c16rkc (06-28-2023), christ (07-03-2023), Hooli (06-29-2023), Ken Cantor (06-28-2023)
  #59
Old 06-29-2023, 03:37 AM
c16rkc's Avatar
Wonderfull!
I hope she does you proud, she was a lovely car to drive when we did a long journey to Cumbria and took in the lake district a few years ago.
The Daimler is also looking stunning with your number plate on!!
The following 2 users liked this post by c16rkc:
christ (07-03-2023), markdpeter (06-29-2023)
  #60
Old 06-30-2023, 01:41 AM
markdpeter's Avatar
Default It was all going so well
We made it to Portsmouth in splendid fashion. 290 miles of comfort at an average of 60mph and 28mpg.
Unfortunately, the consumption of brake fluid was a little more worrying. At first we thought this was just the settling of the levels after the replacement of the front discs and pads. On closer inspection, however, we spotted fluid dripping from towards the rear of the front to rear brake line. Corrosion had been spotted on the inspection and the lines are due to be replaced in the next couple of weeks so it’s cruel that they break now.
The Daimler is heading home on the back of a truck while we continue to Le Mans in a rental…
Very dodgy photo of us confirming that the small puddle under the car is, indeed, brake fluid.
c16rkc (07-01-2023), christ (07-03-2023)
Quick Reply: Mark Peter's Jaguar Ownership Thread
