master key locked in trunk - how can i open trunk now? + RESOLVED
#41
Hi Ken
Good work finding that forum thread ("Any possible way to get the trunk open?").
Since the thread is almost one year old and has 20 postings in it, I though it might be helpful to include a copy of Forum member newuser post# 20 in the thread:
"Just remove the license plate and using a flash light look through the upper screw hole to locate where the latch mechanism is and once you see where it is, stick a semi long thin flat head screw driver through the hole and gently poke the mechanism where you see a small metal tab and it'll pop open."
And the other earlier one by newuser post# 15:
"I got it open in less than 2 minutes with the method suggested above by Gus. All I used was a long thin flat head screw driver and a a flash light to see through the hole and locate the latch mechanism. With the screw driver I lightly pushed on a small metal tab and the trunk popped right open and the valet mode was disabled (no need to disconnect battery). Hope this helps those with the same trunk issue."
I am sure these 2 posts will be helpful to others that find themselves in this same situation.
Thank you Ken for finding the thread.
Jim Lombardi
Jim Lombardi
#42
#43
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
