might sound stupid but... oil change?
Its actually really easy.
The drainplug is 16mm. There might be a plastic vent you have to remove, 7 or 8mm bolt.
Remove the oil filter, double check that the rubber ring on the oil filter comes off.
Tighten everything up. Make sure the oil filter is "tight", i've see a few cars come back with loose oil filters.
Fill 8qts of oil. Check level aftewards and add accordingly if need be.
innzane
09-02-2015 10:08 AM
