Most annoying thing about your X308
I second that one. Happens all the time.
A close runner-up: the damn clunking or rattles in the front suspension, no matter how many things I replace!
Oh wait, maybe it's the placement of the parking brake handle that digs into my thigh on long drives unless I raise the front of the seat high enough to sit more level.
Yeah, that's about it. Trivial things, really.
I have none of the above mentioned issues, perhaps cause I am slightly smaller.
I have to think hard and deep, but can't really come up with anything annoying or negative on this car.
Maybe the high road taxes here for high displacement cars, but can't really blame the car for this ...
Ok, one, the steel sunroof, should be nice if it was tinted glass...
The following 2 users liked this post by ericjansen:
King Charles (01-27-2017),
larney (01-27-2017)
The glass sunroof Murano swap *might* be possible, I saw one at the junkyard and at a glance they look like it might work. Unfortunately I didn't have a tape measure or my torx bits on me to try and stick it in the nearby x308, but I'll go back for that later.
Most annoying, hmm... I could go on forever, but I'll leave out the things that I just haven't got to fixing yet. That front susp clunk is one, I'm thinking those poly shock bushings really are all that bad, but I can't spend the money on foam ones now. Or that damn belt squeal which won't go away, even after new belts and pulleys. Or the strange clicking I get underneath the front end when warm which I can't source. Or that outer bit of wiper blade which hangs off and then smears dirt across that outer edge of the windshield.
Probably what I'm most annoyed by is needing to pull the cooling fan assy just to take out belts. And belts need to be pulled for quite a lot of things. I've hung the fan connector in an easier to reach place, and can probably take the fans out with my eyes closed now. And that the steering wheel doesn't extend out (further front the dash) more than it does.
No contest
Hands down, not even close to whatever's in second place: transmission.
Jaguar Cars and ZF Transmissions should be embarrassed to tears by this complete Cluster-F of a design deficiency. If it had been a Honda, the local dealership would have given me a loaner for the complete time it took to replace/repair the trans, at company expense, regardless of the fact that I'm the 2nd owner of a 15 year old car. Over 100k miles? Okay, maybe I don't get the free car wash.
Only thing I could do - I raised the front of the seat high enough to make it nearly level with the handle, and got used to a slightly different driving position. I usually only do it on trips longer than an hour though. Anything less than that, I can generally put up with it. But going cross-country, yeah, it's painful.
I've never had a problem with the hand brake sticking into me, I find it's ideally located. I like the retro fact that the XK's had it on the door side though. I'm 6ft exactly and average (UK) build, I find the X308 fits me like a glove. I've never bumped bits of me on switches or struggled to get comfortable. I remember reading a quote from Geoff Lawson saying "I wanted to create a car that allowed you to arrive at your destination feeling relaxed and refreshed..." and to be honest, that's exactly what it does.
I've mentioned this in another similar post, but one of the few things that annoys me is the exterior door handles. I think they should be countersunk into the panel, instead of plonked on as an afterthought.
I think the foot wells should be illuminated with the interior lights.
I've also always felt the mirrors are slightly too big for the car's design, they could do with being just a snip shorter IMO.
Lastly, the single wiper seems a bit silly to me. I'm sure a pair of wipers could've been developed. The arm mounted sprayer is useless so I've retrofitted X300 scuttle mounted washers to mine.
But I'm willing to forgive these small blemishes as the rest of the car is simply perfection.
Car comes with 370bhp and a weak open differential. Lack of traction to me = annoying. I fixed that but still a pest to most
Does anyone else find that the front cup holders are crap? Might be that my car came with the special weight saving option to only retain a cup less than 6oz or it will be flipping into the passenger seat
With that being said, still adore my car....most days
So So true, cannot believe this didn't come to mind! I'm 6' and when i'm in a helmet autox'ing or at the track my head is cockeyed and planted into the headliner
