Multi cyl misfire
Multi cyl misfire
Hello everyone, this is my first post so I hope I get it right. My 2000 Jag vdp has multi cyl misfire codes on 5, 6 and 8 cyls the codes that are coming up are
P300, p305, p306, p308, p1314, p0327. The engine will barely run, backfires and dies. Do you think that the faulty knock sensor (p0327) can be causing the issue and if so is there any pics of where it is located. Reading through the forum I see that David N has an excellent explaination on how to change the sensor however my iPad will not download the pics.
Please help
Please help
Like Ross says. Don't try to start the engine again, you may not have caused serious damage yet.
Remove the left (drivers) cam cover and check the cam timing. Rotate the engine clockwise from the front using a 24mm socket on the crankshaft bolt until the flat spots near the front of the cams line up. If they don't line up look at the chain tensioner, it has probably failed.
When you have time, please visit the new member area and introduce yourself:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
FS[MidWest]: 2000 XKR Buy it all!!! $1000
julesjag1
04-23-2016 01:42 PM
FS[MidAtlantic]: Jag tires like new
kenatofc
04-06-2016 11:26 AM
hisport
04-06-2016 10:23 AM
