multiple fault codes, wont start
Old 08-05-2014, 07:08 AM
frankslawn's Avatar
I am having the identical problem...son borrowed car, spun out, hit a curb, broke passenger rear knuckle and wheel...now the car is in failsafe mode and will not even crank....
where is the inertia switch located and how is it reset??? thanks
Old 08-05-2014, 08:17 AM
RonaldP's Avatar
Just a short note when checking the battery voltage. Put the positive lead on the battery post with a good hard push, then check voltage at three spots with the negative lead. 1) negative battery post, 2) negative lead at the post so you read through the connection for a high resistance corroded battery post, 3) a good body ground. That will help rule out the battery charge and connections. You can also do the positive post the same way, with #3 test at the bus bar.
Don B (08-05-2014)
Old 08-05-2014, 10:11 AM
avt007's Avatar
Go to the electrical troubleshooting link in my signature, it has a slide on the inertia switch. Basically it's in the passenger footwell, in the very right front corner. There's a big black rubber button on the top.
Jpav27
07-31-2022 06:43 AM
cissdm
05-03-2016 06:02 AM
OkieTim
09-02-2015 12:48 PM
philwarner
09-02-2015 11:45 AM
Quick Reply: multiple fault codes, wont start
