Multiple Misfires after sitting for a week
2003 Jaguar XJ8 120,000 miles
Car ran fine before. Then it sat for a week. When I started it, it ran incredibly rough and got the following codes
p0300 - multiple misfire
p0301 - misfire on one
p0304 - misfire on four
p1316 - misfire
Ideas lads?
Skipped timing?
p1316 - misfire
Ideas lads?
Skipped timing?
Battery is proper voltage.
I started it up about 5 more times, it was very hard starting at first, lots of sputtering, but now it's almost back to normal. I cleared codes and they have not come back. The engine seems to run smoothly when revved, but has a distinct and rhythmic vibration at idle that shakes the whole car subtly. Fuel trims are proper.
Less than 15k miles on the spark plugs.
I think it's a vacuum leak because it smooths out when I raise idle. There's also a faint whistling sound in the engine bay. It seems that when I let the car sit for a week the seal dried out. As it warmed up, it stopped the leak for the most part. Will replace the intake manifold gaskets and then report back.
Can a bad vacuum leak cause misfires?
