This must be the easiest/most obvious response ever.
I have what must be the dorkiest question;
Removed the interior cowling just inside the grille to replace a headlamp. To do so, I removed six or so of these plastic bolts...they unscrewed right out.
Now, looking to screw the cowling back on, none of the bolts seem to fit their respective holes? How do I screw these things back in? Am I having a brain fart preventing me from seeing the obvious?
1969 Signal Red E-type FHC
1998 Amaranth Pearl XJ8 VDP
2005 SeaFrost XJ8 VDP
1969 Primrose Yellow MG Midget
Are you sure they do not just push in? That is how the similar, engine cover fasteners work in my 2000 XJ8. (X308) Looks like a screw but, is not a screw.
(Just for completeness, as the info is in the other thread(s)...)
Once removed, they unscrew/press out, so the splayed part is not longer splayed. Then they slot in and you screw the central part in (causing a re-splay that holds the parts together).
