My 00' XJR Refresh
#141
I have no issues with the tranny but I think i'm going to add the blue top's during a fluid change eventually... I will also do the rear diff
I went with Royal Purple on the BMW when I did it's "sealed for life" tranny as well... Made it a lot better overall... I looked it up and I don't think it's compatible with the Benz tranny... so ill just go with the best OEM fluid this time around.
I wish I could somehow add the paddle shifters to this tranny, it's been done but I think you need to have the right valve body.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
I like the 100 style knob with the "R" on the bottom.. I think that's sexy.
This car has a long road ahead of it... which I'm glad so I don't get bored with it easily. I've just been constantly researching every part of the car...It also Help's being boosted.
Rlover (10-08-2012)
#143
Research Valvoline Dex/Merc. It is listed in a Merc training manual as being suitable. You can also do some reading at the Sprinter or Dodge forums which use the NAG1 transmission which is the same transmission. The blue tops are well known on the Dodge and Merc forums.
#144
If you wanna read about what and where to get tranny fluid... this is a good read...
Where to buy transmission fluid?? - MBWorld.org Forums
Looks like RP is compatible I must have been looking at an old label on a bottle. The cost of the shell 134 fluid would be really nice though.
Rlover (10-08-2012)
#145
Ok, first item is the transmission dipstick
140 589 15 21 00
Trans Pan w/drain plug
140 270 08 12
Transmission Pan Gasket, Normal maintenance part
140 271 00 80
Transmission Filter, Normal maintenance part
140 277 00 95
Transmission Electrical plug Adapter with O-rings. You need this if you have a leak at the plug on the transmission.
203 540 02 53
Transmission Electrical plug Adapter O-rings. These are replacement o-rings for the above plug.
026 997 40 48 28
026 997 41 48 28
Blue Top Transmission Solenoids
These will increase line pressure and therefore shift firmness in the 5 speed NAG1 Tranny.
240 270 00 89
Enjoy
140 589 15 21 00
140 270 08 12
140 271 00 80
140 277 00 95
203 540 02 53
026 997 40 48 28
026 997 41 48 28
240 270 00 89
Enjoy
Rlover (10-08-2012)
#146
#147
This car has a long road ahead of it... which I'm glad so I don't get bored with it easily. I've just been constantly researching every part of the car...It also Help's being boosted.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
#148
I liked the black trim around the lights as well as the windshield and rear glass so both went permanent with the honda black this week... it's 15 bucks a can haha.. but well worth it.
![Name: IMG_0346.jpg
Size: 48.7 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/159747d1501264229-my-00-xjr-refresh-img_0346.jpg)
Please excuse the dirty car!! Got a new polisher and fixed a powerwasher so full correction write-up will be coming soon.
![Name: IMG_0347.jpg
Size: 108.8 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/159748d1501264229-my-00-xjr-refresh-img_0347.jpg)
![Name: IMG_0348.jpg
Size: 63.0 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/159749d1501264229-my-00-xjr-refresh-img_0348.jpg)
![Name: IMG_0349.jpg
Size: 111.8 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/159750d1501264229-my-00-xjr-refresh-img_0349.jpg)
![Name: IMG_0350.jpg
Size: 81.9 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/159751d1501264229-my-00-xjr-refresh-img_0350.jpg)
#149
looking good, how would you feel about a lower mesh grille? I have one and I think it looks awesome.
I'm not sure how dedicated you are to the blacked out look, but I've always been curious about how black sprayed mesh would look...just a thought
Jaguar XJ8 XJR Lower Mesh Grille Grill for Jaguar XJ8 XJR
#151
#152
to test blacking out the headlamp bezels wouldn't be difficult for test purposes, just run black electrical tape around them and take some before/after and different front end angle shots.
They're stainless along with the window surrounds so I'd suggest a good etch primer coat before using the Honda paint. The original Euro blackouts are powder coated.
Rlover (10-13-2012)
#153
The beauty of the paint is that it don't really need anything to work... but I scuffed everything with a scotch bite and it worked fine... I would also recommend a good cleaning with alcohol/water after.
The trick is to tape the rubber around the chrome in a way that it pulls it away from it. Then run tape around the edge lines, and proceed to do multiple light coats... I used a heat gun to cure it faster and sorta bake it on in between.
Ill probably test the headlights, you guys have me curious now
Rlover (10-13-2012)
#154
Ill probably test the headlights, you guys have me curious now![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
#155
Well, finding the clear rear turn signal bulbs locally was a bust... all amber... soo.. i did some research and found these...
![Name: rearbulbs.jpg
Size: 102.9 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/159664d1501264067-my-00-xjr-refresh-rearbulbs.jpg)
They are currently on sale on amazon for 3 bucks
You guys might wanna grab a set and clear those lights up! I can't wait to have a newer look...
Rlover (10-16-2012)
#158
#159
