This Is my first non x308
Old 05-21-2021, 09:41 PM
BobRoy's Avatar
I saw your post on the x100 site. I'll let other members respond to your post so you can get different opinions. That is too good looking of a car. You will get it up and running.
Old 05-27-2021, 01:21 PM
Vonnslingo's Avatar
this is my progress.first removed
Old 05-27-2021, 02:26 PM
BobRoy's Avatar
Looks good. I would check your octopus and valley hoses for their condition. On the XK8 now is the best time to do the bushings and shocks. With it on the table it is a 1000 times easier to do the job. Check transmission cooler lines for any wear, they sometimes rub on the steering and can leak. In general check everything now while it is easy to get to.
Old 05-27-2021, 03:30 PM
Vonnslingo's Avatar
I am a bit overwhelmed with this project.. this is the direction I think I’m going to go. When I get the XJ8 over there on the lift I think I will use a hoist to get the motor out basically it’s a short block now anyway. And I plan to lift it up the top as the transmission has many less miles I plan to use it. So this new motor I just pulled out will be separated from the transmission is still functioning. I understand that they might have a different flex plate on the back of the engine or it’s possible they have the same one ? I thought I would replace the rear main seal before I install it back in the new car. Yes I had been counseled about the cooling lines under the manifold and the octopus and I agree a lot easier to change now. I just got an engine stand to borrow and I’m gonna go borrow a engine hoist so that he can separate both those I forgot to take out the three torque converter bolts when it was up on the lift damn. Oh well what doesn’t kill me makes me stronger
Old 05-27-2021, 04:35 PM
xalty's Avatar
Received 1,060 Likes on 851 Posts
the engines are the same. only 98 NA motors need modification
some front drive pulleys might be different, double check them
Old 05-27-2021, 04:44 PM
BobRoy's Avatar
You might check the transmission cooler lines. They might be different from XJ to XK. I think the radiators are different.
Old 05-29-2021, 07:35 PM
Vonnslingo's Avatar
The XK is back up on the lift and this is the XJ motor that is going to go in it. I’m going to pull the XK motor wood is basically blocks a short block and install this XG
  #28
Old 05-29-2021, 07:48 PM
Vonnslingo's Avatar
So I spoke to a former Jaguar technician and he could help me with what I wanted to do his point was if I took it out through the top I can leave the air conditioning and the power steering in the car then I don’t have to recharge them and taking it out the bottom was a big problem it seems like a huge mess with a lot of pieces. Anyway he says that when you start taking the motor out and get it up high enough you can get to The bolts and pulleys to the air-conditioning and power steering then when you do the reassembly and are dropping it back in that is when you can hooked everything back up it sounds good I’ve got this motor out of the car already so I get a chance to see how everything hooks up and what to look for I hope to get this XK running and it just wasn’t a waste of time
Old 05-30-2021, 07:29 AM
Addicted2boost's Avatar
Received 1,089 Likes on 839 Posts
Make sure to swap the alternator bracket, power steering/A/C compressor bracket over from the old XK8 engine over to the XJ8 engine.
  #30
Old 06-03-2021, 02:31 AM
Vonnslingo's Avatar
Aa Extreme heat in the northwest we got up to 100 days ago 97 yesterday anyway I need to stay out of the sun so says my dermatologist. I went out there tonight finally and got a few more things disconnected on it I ended up having to takeoff the catalytic converter‘s downspouts as they won’t letGet transmission bolts out. Then there’s so much stuff to go bolted the harness off of this one.The water system is so tight behind it well where the old down throttle body was anyway I have not given up we just gotten so hot around here
BobRoy (06-03-2021)
  #31
Old 06-04-2021, 11:32 AM
Vonnslingo's Avatar
The interesting part is that you can leave the air conditioning and the power steering and power steering in the car then I will get back up with a new motor I hope to do an install tonight
  #32
Old 06-04-2021, 05:01 PM
I hate to say it but those motor mounts looked trashed and now is a good time to install new ones.
  #33
Old 06-05-2021, 07:08 PM
Vonnslingo's Avatar
‘It has a new motor from xj8.
The following 2 users liked this post by Vonnslingo:
BobRoy (06-05-2021), eliotb (06-06-2021)
  #34
Old 06-09-2021, 11:02 PM
Vonnslingo's Avatar
The XJ motor is back in this car everything is hooked up as far as I can tell and I went to test it tonight it did not start. So I dumped a little fuel in it through the throttlebody and it fired up then died I can hear the pump running or starting but I’m not getting any pressure at the Schrader valve it has a little fuel there but not much . I was really hoping for some progress as this has been a long ride. I went to go plug a OBD reader in at the usual spot at the xj8 No I got a find it I am not looking forward to a fuel pump change it it could be a fuel filter who knows
  #35
Old 06-09-2021, 11:32 PM
Vonnslingo's Avatar
This is my second post for the night and then I’m clocking out on this project. I checked the Schrader valve and I’ve got 32 pounds of pressure lots of pressure when keys on. It gives me a P0197 and p1229. It will run if I don’t fuel in it but it will not stay running it has fuel at the Schrader valve but it will not start any ideas on what I’ve done wrong or that I might not have hooked up? I think I’ve got pretty good connections on everything but it is so tight. Even tighter than an XJ8. The differences between the two swapping the motor is minimal and as long as you have two cars or both engines you have the parts you need. But you have to use different hoses because of the low profile hood off of the radiator and other things like that just because of the low profile . And then they have a aluminum sub frame that puts the motor a little bit lower compared to the steel one from the XJ.
  #36
Old 06-10-2021, 10:49 AM
Vonnslingo's Avatar
BobRoy (06-10-2021)
  #37
Old 06-10-2021, 10:51 AM
Vonnslingo's Avatar
It sounds like because I did not swap the flex plates is how come this will not start and run apparently the XK had an updated flex plate and the XJ did not even though they were five months apart? If this is the case I will try to take it off the transmission rather than pull the motor again to swap the flex plate
BobRoy (06-10-2021)
  #38
Old 06-10-2021, 02:12 PM
Vonnslingo's Avatar
So I will put in the car up on the lift today and taking out the crank position her and then I will count the holes on the backside this is where it’s all happening. Then I can pull the flex plate off of the second motor because it’s on the ground and I can count the two to compare it I guess I’ll get me an ink pencil in market then rotate it around completely slowly and count the holes that’s the only thing that Is what has been suggested to me
  #39
Old 06-10-2021, 02:57 PM
xalty's Avatar
unless one of the cars is a 1998 there’s zero chance the flex plate is different
Vonnslingo (06-10-2021)
  #40
Old 06-10-2021, 05:16 PM
Vonnslingo's Avatar
I counted both of the flex plates both have 36 holes
Quick Reply: This Is my first non x308
