Is my fuel leak coming from my filter? [VIDEO]
Hello all, I posted a few days ago about a leak on my x308. Until today was I able to take a look under the car and try to find where it was coming from. The fuel lines and everything looks dry, except the filter. I have linked a video below so you can all see for yourself.
Thanks.
Thanks.
Thanks.
https://youtu.be/3PW1LLr_dOA
Thanks.
ericnunez (08-03-2023)
Well everything around the filter is bone dry, quite literally. I'm just wondering if maybe the fuel was leaking on the outside of the filter pipes, coming from somewhere else. But will do! Speaking of fuel, how do I siphon it out, do you know? I tried taking it out of the tank but it just won't come out. Even with a pump. It should come out because I have around 12 gallons in there.
There are cheap "transfer pumps" on the market for that purpose.
However, I am not sure, if you need to empty the tank, if you swap seals and filter fast enough - but but all means, try if you can get the fuel out with a transfer pump.
Your video suggests what everyone else if writing: It's the seals (well, if there were seals to start with - I work on different Jags all the time, and I do not know, if you are supposed to have seals there - if not, you simply have not fastened the nut there firmly enough - which could also be the case, if you do have a seal in there.
You mentioned above a "high pressure" and a "low pressure" side of the filter. Well: It's just a filter! If the filter is not utterly clocked up, there shouldn't be much of a pressure difference between the "in" and "out"...
I'd say, change a fuel filter every 40.000 to 80.000km.
PS: But change a fuel filter immediately, if you figured out that your fuel had gone bad (fuel can get old and sticky after several month). In that case remove all the fuel, hope, your fuel pump has not died yet, and change the fuel filter.
ericnunez (08-04-2023)
As for draining the tank, from what I've heard, fuel will leak whether or not you drain the tank or not, as there will be fuel in the return system still. The best you can do is remove the rear left wheel to access and remove the filter from the left side, AFTER de-pressurizing the fuel system.
I dont think the gas in there is old, previous owner was using the car on the daily and so was I as soon as I got it. And no worries! Will definitely change the filter. It appears it hasn't been changed ever.
Once again, thanks!
I use O-ring seals made from NBR material for A/C lines, and those same rings are also used for contact with oil and/or fuel.
I have a whole box of those. There are really cheap. They are green coloured.
I bought them on Aliexpress.
Seals are required all the time for everything. I had enough recently that I have to wait a long time for every single seal and apart from the box, I bought now pretty much all sizes up to 32mm diameter and above. Of course there are different CS (corss-sections) as well, but I mainly stuck with 2.5mm, and some 2mm, All on Aliexpress. Of course generic. What's the point of a Jaguar branded O-ring? All it is: A generic O-ring sold by Jaguar...
ericnunez (08-05-2023)
This fuel filter was used on a lot of GM cars of the era. Apparently, Dorman 800-013 includes the pair of o-rings, about $6 on rockauto.
Seals are required all the time for everything. I had enough recently that I have to wait a long time for every single seal and apart from the box, I bought now pretty much all sizes up to 32mm diameter and above. Of course there are different CS (corss-sections) as well, but I mainly stuck with 2.5mm, and some 2mm, All on Aliexpress. Of course generic. What's the point of a Jaguar branded O-ring? All it is: A generic O-ring sold by Jaguar...![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
As I wrote before: I assume that, if you buy a Jaguar branded O-ring, you just buy the same O-ring, that you can buy from China directly, just heaps more expensive. Jaguar does not manufacture O-rings. And Tata-Jaguar most definitely does not manufacture Ford-Jaguar O-rings... How wrong can a seal made of the correct material in the correct size be? Sure; The one thing they do not have in China most of the time is a quality control department - so you just buy 10 seals, do the QC yourself (visual inspection) and possibly throw one away. I actually just had a seal with a bit of a manufacturing damage in my hands yesterday. So what? Flick it and take the next one...
