My jag gurgling under sudden acceleration
It's been while I have this problem it only occur when I hit gas pedal hard like from zero to 40mph between 1to 3 rpm the car have like gurgling noise! Then after 3 rpm the car goes smooth and fast . I'm planning to replace the spark plugs and spark plugs seal and pulling the intake manifold to clean the injectors and the throttle body maybe also replacing the intake manifold gasket if it's not cracked I like to add some gasket maker and re install the manifold ,
I'm not sure if this will solve my issue any other ideas ?
Xj8 here not xjr
Xj8 here not xjr
VTGBoss
07-23-2021 03:04 AM
androulakis
16
03-31-2010 01:31 PM
