My Oil is Leaking! 1999 XJ8
Help...once again I turn to you all...My engine fail light come on last night...looked this morning to see if any leaks were there...and yes,,,oil is leaking! Is this something easy to fix or bad news? Exspensive to fix ???
Please advise if you can!!!
Thanks, Elizabeth!
Thanks, Elizabeth!
Received 2,193 Likes
My oil is leaking!
The check engine came on for a small moment then it went to traction fail. I topped off the oil because it was alittle low from the leak...drove for awhile with no problem until I drove her later....then it happened again. From what I understand this traction fail thing is a sensor letting me know something is wrong, obviously, but where would the oil leak be coming from? The pan? I keep trying to find the route at which the oil flows to figure it out...
Thank you all for helping me out..again!
I love this site!
E
I love this site!
E
most oil leaks on your car are at the back coners of the cam covers, and if your gonna do those replace the upper tensioners while in there since thats half the labor. Traction control on your is a wheel speed sensor, throttle body, abs module. But your really need to have the codes checked to accuratly diag, other wise I could do better pulling likely problems out of a hat
aholbro1
08-05-2021 05:02 AM
