Mysterious coolant leak
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
99 XJ8 4.0 L. Having to top up coolant daily, usually about 8-10oz, with minimal driving. Just gone over 200,000kms. I can smell the coolant when exiting the vehicle, no sign of leaks on the ground or in the engine compartment. Coolant sensor is functioning normally. Thermostat tower was replaced with the aluminum upgrade 6 months ago.
Any ideas where to look? Any and all help gratefully appreciated.
if you smell the leak and it isn't coming from the tailpipe you will have to look at the whole system pipe by pipe, some less obvious places are hoses under the inlet manifold, heater core and overflow bottle under the left fender but that one would rather not smell, all other stuff is easy to access, you may help yourself and add uv dye to the coolant and look for leak with uv light,
Garethster (05-20-2021)
Garethster (05-21-2021)
yep, dye is so good that it taints leaks which normally would classify for attention, but setting it apart, if Garethster can smell coolant then it should be relatively big and easy to find, perhaps having contact with hot stuff like engine or exhaust otherwise smell wouldn't be noticeable outside, most of coolant stuff is routed easy to inspect way so some searching with flashlight or even smelling around to narrow the location should suffice well before 15th
jmcGoBlue
03-05-2012 11:41 AM
stephen11962
12-06-2010 07:38 AM
