Mystery Suspension clunk...driving me NUTS
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
02 XJR with 105K...I have gone thru everything...what am I missing; Clunk is front right happens ALL the time over light bumps in the road...have replaced and eliminated the following;
Both Ball Joints AND both sets of A frames bushes upper and lower
Track rod end
Rollbar bushes AND down links
Cats Shocks and upper mounting bushes
Is it possible for a subframe mount to go bad...they seem fine. Nothing loose under floor...transmission mounts good...definitely comes from lower right front suspension...it's not the door hinge or inside the door cavity....I am stumped...anyone?????
Track rod end
Received 2,192 Likes
I'd suggest engine mount, I went through your exact list.
https://www.jaguarforums.com/forum/a...pictureid=4635
no totally differant, the 98 later use a slide out lower mount so that when you pull up too far on a parking curb it pushes the radiator out and back to limit damage if any. It can be slid back in and unlike 95-97 wont break the radiator or bend the lower radiator metal bracket(big improvment thank god)
driver safz
09-26-2015 06:01 AM
