Need Assistance- 2004 XJR -Wipers Home Position Up Not Down
Guest
Posts: n/a
Tried moving the arms but no luck so it must be different than the early ones. I suspect a home position sensor must be bad or moved but I am not sure if this is separate from the motor. I attempted to remove the panel above the wipers but I could not figure out how to remove the windshield side which has a seal attached at the bottom of the windshield. Anyone else no the fix to this problem or how to remove the panel withour destroying the seal?
Thanks - Chris
Thanks - Chris
Rlover
03-30-2016 10:04 PM
