need help
need help
can anyone explain why and how on a 04 xjr the IAT's .. when sitting in traffic temps rise to about 130-140 but when flooring it and staying on it the IAT's drop low like to 100f and its doing this in 90 degree weather .. i drive a e55 amg and when i get on it the temps rise not lower but my best friend just bought this 04 xjr and we're trying to figure out the car .. and input would be great thanks .... and also what are the best mods for this car as well
The IAT is part of the MAF sensor and is just downstream of the air filter so heat soak from the engine compartment will raise the temp but a strong flow of fresh air will reduce the temp. Perhaps the temp sensor on another car is a measure of intake manifold air temp so a compressed air charge (supercharger/turbocharger) will normally rise even after the intercooler. It all depends on where you take your reading.
bob gauff
bob gauff
bob gauff
bob gauff
gonna say you won't get many responses with the simple title 'need help'. I would recommend you be more specific, like "IAT temperature fluctuation".
You're the only one who knows what your code reader will read, in live mode. My software allows various options on what to observe/record, so I can select whatever I choose.
For performance mods (pulleys, porting, etc) check out the previous threads in the XJ and S-type section (and now the engine section), the engine sizes and supercharges are similar, you'll get an idea on what can, and can't be done.
bob gauff
bob gauff
This is testimony to the factory air intake design.
I concur with Bob. The MAFS is a dual sensor - air flow and temp (IAT - using a hot wire sensor). This sensor is right behind the air filter and before the CV inlet in the intake tube so the sensor stays clean. The temp readings you are getting are just what is to be expected as the factory design draws fresh air from outside of the engine compartment.
I dont know much about these cars but my Mechanic does! lol You might want to give him a call. He's in Downey, CA but he might have the answers to your questions! His name is Rigo Campos, 562.869.8232 Biz, 562.477.3052 Cell, rigo@downeyjagandlandrover.com.
