Need help with door locks PLEASE...
Hi fellow Jaguar friends...im new to the forums and was wondering if anyone can help me with my problem.
I have a 99 Jaguar xj8 vdp and problem is....
1) When i lock the car using the key fob...the gas door and trunk will lock but none of the doors.
2) When i lock the car using the actual key...the driver's door, gas, and trunk will lock but none of the passenger doors will
3) With the car running...when i push on the dash lock/unlock button nothing happens but when i hold it down for a sec...i can hear a click sound at each door but doors will not lock.
4) I can manually push down and pull up lock at each door.
If someone can please help me with this issue it would be greatly appreciated. Thanks
You can research the forum for more information but it basically reboots the computers. The reset can be done by removing the ground strap from the negative post of the battery and touching it to the positive post on the battery for approximately 30 seconds. You probably will loose some memory settings for things like the seats and mirrors but you can reprogram them.
Here is a copy of probably the best DIY on hard reset post (created by forum member SuperSport) Proper Reset
This is the post contents:
While a Hard Reset is very easy to do, getting the connections wrong can have catastrophic/dangerous results, so here is how it's done safely.
1. Turn Key OFF
2. Remove Negative Battery Terminal from the Negative Battery Post (10mm Wrench)
3. Turn Key ON
4. Touch Negative Terminal End to Positive Terminal End and hold there for 15 'ish seconds (Positive Terminal will still be connected to Positive Battery Post)
5. Turn Key OFF
6. Reconnect Negative Battery Terminal back to Negative Battery Post
NOTICE: On First Start after the Hard Reset, let the car idle for a minute or two without touching throttle. This allows the computers to recalculate the throttle position, etc... Also, the car may drive differently for an hour or so while it's relearning your driving habits.
See Attached Photo showing Correct Short for Hard Reset
NOTICE: NOTHING CONNECTED TO NEGATIVE TERMINAL
Here is the weblink to SuperSport post:
https://www.jaguarforums.com/forum/x...12/#post702404
actual full - webpage address (you will need to add the www. before the jaguarforums)
***jaguarforums.com/forum/xj-xj8-xjr-x308-27/hard-reset-38112/#post702404
hope this helps
Jim Lombardi
ps - if you cannot view the photo, you can use the following weblink to my dropbox to view it: (note when dropbox opens - if it asks you to join dropbox - just use the option to view the photo file on the lower section of the webpage)
https://www.dropbox.com/s/kpuec9oki6...photo.jpg?dl=0
actual full - webpage address (you will need to add the www. before the dropbox)
***dropbox.com/s/kpuec9oki60idck/hard%20reset%20photo.jpg?dl=0
1. Turn Key OFF
3. Turn Key ON
5. Turn Key OFF
hope this helps
Jim Lombardi
Samilcar (03-26-2016)
1. Turn Key OFF
3. Turn Key ON
5. Turn Key OFF
hope this helps
Jim Lombardi
1. Turn Key OFF
3. Turn Key ON
5. Turn Key OFF
hope this helps
Jim Lombardi
(Although the hard reset did have my trunk lights working again : )
1. Turn Key OFF
3. Turn Key ON
5. Turn Key OFF
hope this helps
Jim Lombardi
1. Turn Key OFF
3. Turn Key ON
5. Turn Key OFF
hope this helps
Jim Lombardi
There is a door lock relay that might be the issue. It is located in the LH Heelboard. Behind the left-hand side rear seat heelboard -Door lock: micro-relay.
I extracted part of the electrical diagram that shows the location of the relay:
https://www.dropbox.com/s/wncbwedd0r...20Location.jpg
Here is a youtube video on how to test a relay:
http://www.bing.com/videos/search?q=...BA81&FORM=VIRE
Relay part number is LNA6705AB
Relays - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Heritage Parts UK
item 2, micro relay, black, door lock - LNA6705AB
Here is also a fuse for the door lock relay and door locking actuator - located in the rear compartment - right hand heelboard
Fuse #2 15 amp
Fuse #2 15 amp
The following 2 users liked this post by jimlombardi:
Jhartz (03-28-2016),
rocklandjag (03-28-2016)
1999 jaguar xj8 LNA6705AB relay in engine compartment - Bing video
Fuse #2 15 amp
Fuse #2 15 amp
dinty (09-03-2019)
I know this is an old post but hoping it’s still being viewed…
my wife’s 1998 XJ8 VDP has the same issue with all door locks and the fuel door. Remote FOB actuates locking and unlocking of the trunk and the security system. I’ve tried the rest as described above with no results. I did replace the 15amp starboard heel fuse box associated with the locks. It was blown. I replaced it and again, no results. That’s kind of strange but it was the first thing I did. Conditions remain as it was originally. The dash message at the speedometer window says “BOOT OPEN” but I have triple checked to insure everything is cinched up and closed tight.
she can use the car and can lock/unlock manually but it’s a PITA.
ANY HELP IS CERTAINLY APPRECIATED.
It’s possible given the age of your car that all the door locks need to be pulled out of the doors and throughly cleaned and lubricated. I’m not saying that’s exactly your issue but one worth looking into. I know there’s a microswitch that can also get stuck in the door locks and not turn on the puddle lights with the doors open. Same scenario, needs cleaned and lubricated.
Rickkk
03-21-2017 12:02 PM
