need help with oxygen sensors (universal)
Hi everyone, I just bought universal 4 wire (bosh) oxygen sensors (no connector) and I need advise with connecting it. the colors and meanings are: black-oe signal; white-oe heater; white-oe heater; gray-oe ground. anyone could explain me how should i mach the colors ? thaks in advance
The OEM sensor's wiring coming from the sensor (the wires from the sensor to the connector). This is if you cut the connectors off of the existing OEM sensor and want to splice it onto the new sensor:
Blue: signal
White: signal ground
Black: heater
Black: heater
Heater signals are not polarity sensitive - you can hook in either direction.
If you are interested in the color codes from the connectors to the ECM:
from the bank A connector to ECM (HO2S A):
Red: signal
Braid: signal ground
Purple/Blue: heater
White/Purple: heater
from the bank B connector to ECM (HO2S B):
Green: signal
Purple/Slate: heater
This is referenced by the 98 XJ8 Normally Aspirated, Rest Of World (I assume you have an ROW vehicle from your location)electrical diagrams (linked below) - see top right of Figure 4.2
http://www.captainjaguarscathouse.co...ec%20Guide.pdf
Blue: signal
Black: heater
Black: heater
Red: signal
Purple/Blue: heater
Green: signal
Blue: signal
Black: heater
Black: heater
Red: signal
Purple/Blue: heater
Green: signal
Blue: signal
Black: heater
Black: heater
Red: signal
Purple/Blue: heater
Green: signal
