Need Help Replacing Thermostat Please
Received 4,325 Likes
I like the rubber seals much better than gaskets. It's the same with the valve covers and the water pump. You just smear some a little Vaseline on them and tighten just enough to squish the seal. 8 Nm equal 5.9 pound feet of torque - not much.
forum member xjay8 uses a 2 way suction pump to remove enough coolant to do repairs:
The only Hand suction pump that I could find is on the Harbor Freight website
Looks like you have a local Harbor Freight store (1460 South Broadway, Santa Maria, CA 93454 (805) 922-4337)
Jim Lombardi
Jim Lombardi
bigcat777 (05-07-2015)
The following 4 users liked this post by jimlombardi:
But with either model, I don't even take the radiator hose off. I just remove the bolts, pop the t-stat out, put in a new one, bolt it back up. Good to go.
bonez817 (10-20-2015)
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
