need help with t-chain tensioner
i need help choosing the correct timing chain tensioners for my 2000 jaguar xj8 . i am going to replace the original plastic ones for the metals ones so can somebody post a link to the ones i should get or a pic of how they should look cause i seen a few but i don't want to end up getting some really poor quality aftermarket ones but not too expensive just reasonable thanks!
Received 4,325 Likes
here is the link from the how to's portion of this section - scroll down to the embedded links and it is the 5th one
https://www.jaguarforums.com/forum/x...k-links-20090/
if you can't find there - here is the link to the actual download:
http://www.mediafire.com/view/?wnuacwgt22023o9
I and many others used tensioners for the '01 Lincoln LS, same part but cheaper. Order 2W9Z6K254BA and 2W9Z6K254CA and four shorter bolts W500301S300? ( someone please confirm). I ordered from sunroardfordparts.com. You need felpro gasket set VS 50724 R which you can buy at Autozone, etc.
mikiep
12-20-2019 07:37 PM
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
