Need a little help with a cooling fan issue
Hello,
I have a 99 XJR The fans do not ever come on. I have read numerous threads about the fans. I am assuming that the fan relay controller is the issue?
If I understand correctly the fan control modules activate 2 relays 1 for each fan.
I am wondering if the 2 relays in the attached photo are the fan relays?
Also if I understand correctly the fan control module is buried somewhere under or around the left headlights?
What is the easiest way to access it?
I can't seem to find / see it to save my life.
I did the test placing a 100 ohm resistor across the temperature sensor plug without success.
and both fan fuses are good.
Any advice would be greatly appreciated
Snookfever
04-09-2016 02:05 PM
sempaipaul
03-14-2007 11:37 PM
03-13-2007 12:07 PM
