need a new Mass flow meter MFS
Hi to all, I took my car 2000 XJR to Jagpro,Bellmore NY and Martin told me that my check engine light was related to the Mass flow meter.
I actually replaced one(used)last year as had shifting problem,but Martin said that I had to install a brand new.My question -is it ok to replace an aftermarket one from autozone since the price quoted only around 150 , that is way cheaper or still OEM for jaguar rules?
Martin also said about the TPS issue, he said hopefully the issue was not on the throttle-body, but perhaps just wiring/electronic
please share some thoughts with me
Can you buy a cheap code reader and report back?
If you're still dreaming, buy these and bolt them on! you'll need discs Good luck
Jaguar XJR v8 supercharged brembo type R break 4 pot calipers full set | eBay
