Need New Transmission Please Help
![Thumbs down](https://www.jaguarforums.com/forum/images/icons/icon13.gif)
I just found out that my Transimission is shot on my 1998 XJ8. I need to know how much will it cost to replace it( rebuild or new) I am located in NJ USA does anyone knows good place that could help me out getting one? I have someone to replace i just would need the transmission it self.
Thanks in advance
Thanks in advance
You can get the transmission itself (rebuilt) for about $2100, plan on at least $800 to install depending on the shop and what kind of deals you can manage. If you have a shop around there that specializes in BMWs or Jags, they might be willing to do a rebuild, that would be much cheaper. The 5HP24 was used in 97-02 540 and 740 models as well as the Jags so that might give you a few more options.
You have a few options. AAMCO quoted me approx $4K to rebuild mine out the door. Or you can go to http://www.car-part.com/ and see if you can find one here. I found a used gearbox for my '01 XJ8L with a 2 year full replacement and labor warranty for $1200.00 delivered. Another $850.00 and it was in the car and running. In this case you will need a few parts like a front seal, pan gasket and filter as well as some very expensive transmission fluid. You would be hard pressed to come up with a deal like that unless you have a few favors due.
Lastly, you could rebuild and reinstall yours for about $1K and the additional labor.
Marka
22
09-11-2016 12:09 AM
dmatthewman
09-30-2015 10:10 AM
