Need to replace Knock Sensor...Bank 2 location?
I am getting the code P0332 Knock Sensor 2 Circuit Low Input (Bank 2) on my 2000 VDP. Looking from the front of the engine Bank 2 is the right side (driver's side), correct? Just want to make sure I replace the correct one. I only have one replacement sensor. Thanks!
The normal method of expressing engine left and right is from the driver's seat. From that position bank 2 is the left side or as you described it up to the point of adding 'driver's side'.
You have to be real careful describing 'driver's side' on a British made auto.
Good point. I just replaced the wrong one because I assumed Bank 2 was the passenger (American model) side. Now I have to replace the one that was actually bad (driver's side). Oh, well.....
KarimPA
09-03-2015 07:32 PM
rachelstr
09-03-2015 12:59 PM
